BigBadBiologist
- Mar 19, 2001
Here's a little rundown on how I stealthed my DVD drive on my SB65G2V3.
So here's what it looked like to start (OK, but nothing special):
First thing I did was marked approximately where the screws go through the SB65 bay blank (you can see the pencil marks):
Second, I covered each edge (making sure to go past where the pencil marks were) with a nice thick coat of JB Weld:
Next, I broke one of those plastic things that are at the top of CD packs so that each side of the tray cover was on the plastic and squished the tray cover face down onto the plastic:
When the glue was dry, I peeled the plastic off of the tray cover:
This leaves a nice flat surface for the blank to sit on:
From here I sort of stopped taking pics, but basically I just sanded the edges flat and the hardened JBWeld through the holes of the SB65 bay blank. Then I drilled holes through the tray and used the SB65 bay blank screws to attach the blank to the DVD tray cover and snapped it back onto the drive:
I need to get a couple better pics of the done project, but you get the idea.
Questions:
-Why not just use double sided tape? -Well, I've tried that and it feels flimsy to me. Plus, this bay blank is actually two pieces (plastic and aluminum) and two screws.
-What about the eject? -Well, I haven't totally figured that out yet. For now, I'm just using eject from within windows. *PROBLEM SOLVED, CHECK MY POST BELOW*
Questions:
