SpasticTeapot
- Sep 21, 2004
This is my most recent Art Metal project. I've also been working on my own LM3875 amplifier boards that should fit inside just fine, with plenty of room for a volume potentiometer. (the PSU would be outboard.)
The sides are Socket 370 heatsinks leftover from dead PC's, the lexan was a piece of scrap I found, and the copper bits were leftovers from someone else's project. The epoxy, however, was not recycled.
It's not done yet - I'm adding a small faceplate, polishing it, and adding a clear varnish to the colored-metal bits to bring out their color better.
(If you're wondering, I applied bits of flux to the shaped piece of metal, and heated it, while cooling it carefully. End result? Pretty oxidation. The texture was produced by good, old-fashioned hammering.)
The next one's going to be made out of wood instead of Lexan, and likely use larger heatsinks as well.
