my hard specs help!!
altec
ok have no ideal what is in my puter all i know is the mem is 256mb and the hd and the p3 466 you get it.
well i want to see more of what the hardware is so does any one no a program that can tell my all the specs all the specs.
K well I know your under 14 from the way you just posted that. Please learn to use commas and periods to type your sentences.
You can download a program called CPUZ and that will tell you what you need.
