Hi,
Some of you may have read my posts lately regarding aftermarket cooling for both the 4870 and the 260. I have had nothing but trouble with the 4870 regarding how HOT it gets and heating up my room...you can read people making fun of my comments in the ATI forum in general attacking me personally because I returned that card cause it was so hot; it got up to about 103/104C!
Well, after all that I thought, "maybe I was wrong, that 4870 is alot of bang for my buck....I guess I'll try again"....so I bought another 4870 and it was exactly the same. So, me being a long time nvidia owner anyway, I said, well, screw it....if nvidia makes a more stable and better put together card with more attention to noise and heat, I'll try that....
So I started thinking about getting a 260. Then I said, I might as well get the 280 cause I want as big a difference as possible and to me the 150 difference isn't enough to worry about long term. Excited, I headed to the local frys to get my 280 after reading some reviews and seeing temps pretty low compared to my 4870 experience.
Well, I got the EVGA 280 and fired it up, played crysis for about 2 minutes and the thing was at 102C! oh boy. I experimented with it before returning it and I bought a BFG 280 oc and another EVGA.
With the BFG in, I fired it up and played crysis (that game will get these cards hotter than furmark in my experience) and the same thing.
"I might as well not even try the other box" I thought. But since I bought it just to try, of course I did. With my final card in there, I started things up and opened the precision monitor....well, weird, I've never even seen temps in the 50's before! Also, it's leveling out around 69C.
Now I know some of you may think that's high idle, but I have a cosmos case and it's loaded with fans in everyplace they meant for them to be and that's as good as it gets for airflow. The point is, it wasn't idling in the high 70's. Ok, good start!
TEMPS:
Started Crysis and low and behold, with the fan charging up to about 90%, the card never breaks around 82C-83C! this is great! I played team fortress 2, which on the 4870 brought me temps of 102C, and the 280 didn't get over about 76C; WOW!
FAN:
Another thing, the fan on the 280 is SO much better than the 4870; which sounds horrible and way loud. This fan is very tolerable, more of a whooshing sound and it blends right in. Right now, it's running at 41% idle, the temp is 68.
So my whole point is, if you have one of these cards that shoots up to 100+C, if you can, return it as you CAN find a card that will run alot cooler. If you can buy locally, do so. I really think the best idea is to take your credit card to a place that sells these things with a good return policy and buy 3, if the first one is good, fine, return the other unopened. I think the 100C problems people are seeing are just chips that aren't that good...too bad since it doesn't say alot for quality assurance, but the bottom line is you can get a great card that runs relatively cool if you look hard enough. I'm content with these temps and I'm really happy with this 280.
Here's to morning typing! Have a nice day!
TEMPS:
FAN:
