Relevant parts...
- dell 2409W (24" 1920x1080 max)
- asus 27" - shows to nVidia control panel as Ancor Communications Inc
---- native 1920x1200
- aoc 23" (23" 1920x1080 max)
MSI GTX 670
I am using both DVI ports and the HDMI port. I am wondering if using the display port might come into play.
I can say that both playing games with 3 monitors and viewing 3 desktops works. I don't have tons of disposable income, and while a tri-monitor setup was something I always hoped for, it was not something in the budget all at once. So it had to be pieced together. I'm not pulling out a loan for 3 identical monitors.
And here's where the trouble comes into paradise.
When I enable SURROUND, the max resolution I can get is 3840x1024. BF3 looks great, but the FPS are great, i'd like to try 5760x1080.
And i'd also like for the pain of switching from "gaming mode" resolution to "work mode" resolution to be a bit easier.... I can adjust the settings eventually, but I don't know the exact of what to disable, enable, disable in the nvidia control panel and windows control panel. I have found i have to fiddle with both before getting good results.
Would replacing the HDMI with a display port cable then running to DVI solve the problem?
edit* - I have tried adding a custom resolution of Horizontal 5760 - vertical lines 1080 - refresh rate 60 - bpp 32 - scan type progressive. And the screens don't flicker, it just says "FAILED."
MSI GTX 670
