My Ghetto Rig
Yuk
Its not finished, I am waiting on parts to mount the radiator you see thats held in place with a ziptie and it has no power button yet. I also need to go to lowes and pick up some 1/2 inch screws for the fan on the NB. The 2 closest to the cpu are way too long.
and I still can't figure out how to put 2 pics in one post.:mad:
I would consider that much more an unpolished work in progress than ghetto. Really all you need is some wire management and to make something to mount that radiator
u want to make a ghetto pc? then get rid of that fancy case and put all that stuff into a cardboard box
I tried and the second one would just show the link with IMG on each side in white letters. It wasn't even a clickable link.
Why does your ghetto computer has better wire management then mine and has sli video cards?? This makes me want to see your nice computer.
Wire management has never been my cup of tea. I don't know how to sleeve my wires, I need a dead psu to practice on I guess. I don't wat to cut the case to hide wires behind the mobo because I may want to use it down the road for something else.
This is my nice pc, its just not finished. It looks ghetto to me because of the zip ties and the front is unfinished. I actually use this pc as it sits.
