Mar 21, 2011 #2 T tiraides [H]F Junkie Joined Jan 8, 2004 Messages 11,065 Eh, it's better than I expected. Which case are you using?
Mar 21, 2011 #4 Negative Decibel 2[H]4U Joined Dec 13, 2005 Messages 3,588 ive seen more ghetto... not bad.. kind of mediocre... I was expecting something much worse
Mar 21, 2011 #5 Negative Decibel 2[H]4U Joined Dec 13, 2005 Messages 3,588 try sealing the edges with duct tape...
Mar 21, 2011 #6 I icor1031 [H]ard|Gawd Joined May 29, 2010 Messages 1,295 I'm just going to make another one that looks proper, has screw holes, and paint it, I think.
Mar 21, 2011 #7 T tiraides [H]F Junkie Joined Jan 8, 2004 Messages 11,065 You should make the panel large enough to screw it in, as if it was the back of a PSU. You should also space out the knobs a bit more evenly (of course, assuming that you aren't planning on adding more...).
Mar 21, 2011 #8 I icor1031 [H]ard|Gawd Joined May 29, 2010 Messages 1,295 Well, Tiraides.. They are spaced pretty evenly, I just didn't put in 3 of them yet.
Mar 21, 2011 #9 86 5.0L Supreme [H]ardness 2FA Joined Nov 13, 2006 Messages 7,131 lrn2cablemanage besides that, function over form, i like it
