My gaming rig.
KojiRaven
This is my specs for the computer i want to build. What do u think?
LOGISYS Silver/Red SPIDER II ATX Mid Tower Case With
ENGRAVING ACRYLIC LED LIT-UP WINDOW, Model "CS885SL" -RETAIL
Specifications:
Case Type: Mid Tower
Color: Silver/Red
Material: Steel
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB2.0, 2 x audio
Power Supply: N/A
Cooling System: 1 x 120mm rear fan, 1 x 80mm side clear fan
Motherboard Compatibility: ATX 12" x 9.5"
Dimensions: 7.9" x 17.3" x 19.8"(WxHxD)
Features: Blue LCD Thermal Display in front, Special Designed Shutter
Style Air Exit for better and silent performance more info-> N82E16811148011
$50.00
MSI "K8N Neo2 Platinum" NVIDIA nForce3 ULTRA Chipset Motherboard
For AMD Socket 939 CPU -RETAIL
Specifications:
Supported CPU: Socket 939 AMD Athlon 64FX/64 processor
Chipset: nForce3 ULTRA
RAM: 4x DIMM Supports dual channel DDR266/333/400 Max 4GB
Slots: 1x AGP 4X/8X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1x IEEE1394, 2xRJ45,
1x S/PDIF Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
SATA/RAID: 4x SATA RAID with 0,1,0+1
Onboard Audio: ALC850 8-Ch
Onboard LAN: Marvell 88E1111 1000Mbps, Realtek 8110S 1000Mbps
Onboard IEEE1394: 3x ports by VIA 6306
Form Factor: ATX more info-> N82E16813130468
$136.00
EVGA nVIDIA GeForce 6800 GT Video Card With Free Doom 3Bundle, 256MB
GDDR3, 256-Bit, TV-Out/DVI, 8X AGP, Model "256-A8-N349-AX" -RETAIL
Specifications:
Chipset/Core Speed: nVIDIA GeForce 6800 GT/350MHz
Memory/Effective Speed: 256MB GDDR3/1000MHz
BUS: AGP 8X
Ports: VGA Out(15 Pin D-Sub) + TV-Out (S-Video) + DVI
Support 3D API: DirectX 9.0c(Shader Model 3.0), OpenGL 1.5
Max Resolution@32bit Color: 2048X1536@75Hz
Cable/Accessories: S-Video Cable, DVI to VGA adaptor, Power Cable, Manual,
Driver CD, DOOM3
Retail Box (See pics for details) more info-> N82E16814130208
$399.00
Aspire Turbo Case Series 500W 12V Blue Aluminum Power Supply, Model
"ATX-AS500-BL 12V" -RETAIL
Specifications:
Type: ATX
Maximum Power: 500W
Material: Aluminum
Dimensions(DxWxH): 150x168.5x86mm
Shipping Weight: @pc 4.5 lbs / 8pcs Per Box
Features: ATX 500 P4 Aluminum Power Supply, w/See-Through Clear Acrylic
Cover (Fire Resistant Material), w/2 x 8cm UV Blue Fan w/Blue Led Lights,
Multi-Color Coated Components & PC Board, Green UV Sensitive Wiresleeve &
Connectors, w/Fan Speed Adjuster, w/ I/O Switch Cable-Tube-Tied Wires for
Neatness, w/Gift Box more info-> N82E16817148006
$55.00
AMD Athlon 64 3500+, 512K, L2 Cache, Socket 939 Windows Compatible 64-bit Processor - Retail
Specification
Model: AMD Athlon 64
Core: Newcastle
Operating Frequency: 2.2GHz
FSB: Integrated into Chip
Cache: L1/64+64KB; L2/512K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail more info-> N82E16819103463
$282.00
Geil Ultra Series Value Dual Channel 184 Pin 1GB(512MBx2) DDR PC-3200 w/ Blue
Heatspreader - Retail
Specifications:
Manufacturer: Geil
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5 7-4-4
Support Voltage: 2.55V-2.95V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: Optimized SPD for Dual Channel DDR motherboards
Warranty: Lifetime more info-> N82E16820144310
$172.00
Maxtor Ultra Series Kit 160GB 7200RPM SATA Hard Drive, Model L01M160, Retail
Specifications:
Capacity: 160 GB
Average Seek Time: 9.3 ms
Buffer: 8 MB
Rotational Speed: 7,200 RPM
Interface: Serial SATA150
Features: Ideal for high-end gaming and digital video, Ultra quiet operation with FDB motor
Manufacturer Warranty: 1 year
Packaging: Retail (see pics for details) more info-> N82E16822144352
$136.00
Logitech Elite Keyboard USB/ PS/2 104keys -RETAIL
Specifications:
Interface: USB/ PS/2
Number Of Keys: 104 keys + 19 function keys
Wireless Technology: N/A
Palm Rest: Detachable
Features: Ultra-flat, Zero Degree Tilt keyboard design for increased comfort, Nine customizable keys for one-touch access to favorite web sites and applications, iNav buttons and scroll wheel for keyboard-based web navigation, Multimedia keys to control audio and video directly from the keyboard, iTouch software to customize keyboard features more info-> N82E16823126114
$29.00
ViewSonic P95F+B 19" PerfectFlat CRT Monitor –RETAIL
Specifications:
CRT Type: PerfectFlat CRT
Dot Pitch: 0.25mm aperture grille at center
Max / Optimal resolution: 2048x1536 @ 68Hz / 1600x1200 @ 87Hz
Frequency / Bandwidth: fh: 30~110kHz; fv: 50~160Hz / 285MHz
Features: UltraBrite 4X technology
Dimensions & Weight: 18.8" x 17.9" x 18.5" (WxHxD), 51.7 lbs
Manufacturer's Warranty / Phone No.: 3 year limited warranty on CRT, parts and labor. / 800-688-6688 more info-> N82E16824116232
$248.00
Logitech Laser Cordless Mouse (Blue/Black), Model "MX1000" -RETAIL
Specifications:
Interface: USB/PS2
Number Of Buttons: 8x Buttons + 1x Tilt Wheel
Optical/Ball: Laser
Wireless Technology: Fast RF
Features: MX Laser Engine provides 20x times the tracking power of optical, Never worry about batteries again with a built-in lithium-ion battery & rapid-charging base station, Fast RF cordless delivers cordless performance that equals USB corded connection, New thumb-button controls include universal page forward & back buttons & application switch to quickly move between open windows, Illuminated 4-level battery indicator precisely monitors battery strength, Wheel tilts for side-to-side scrolling, Cruise control more info-> N82E16826104158
$75.00
Artec Silver 52X32X52 CD-RW Drive, Model WSM-52Z, OEM
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI/E-IDE
Buffer: 2MB
OS Support: Windows XP/2000/Me/98SE
Features: Buffer Underrun Burn Proved Technology
Packaging: OEM (see pictures for details) more info-> N82E16827120154
$29.99
ARTEC 16X DVD-ROM Drive, Model DHM-G48R, Retail
Specifications:
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: E-IDE/ATAPI
Buffer: 512KB
Access Time: DVD-ROM: average Less than 115 ms, CD-ROM: average Less than 100 ms
Data Transfer Rate: DVD-ROM (Single Layer):22160 KB/s max; CD-ROM (Mode 1, 48x max.): 7200 KB/s max; CD-ROM (Mode 2, 48x max.): 7200 KB/s max.
Features: Horizontal / Vertical mounting, Access up to 17GB of DVD data capacity, Quiet and Good Vibration resistance.
Packaging: Retail (see pictures for details) more info-> N82E16827120506
$24.00
Creative Labs Sound Blaster Audigy2 ZS Platinum PCI Sound Card, Model "SB0350" -RETAIL
Specifications:
Channels: 7.1
Max Sampling Rate: 192kHz
Signal-Noise Ratio: 108dB
Hardware Decode: Dolby Digital EX
Digital Audio: 24-bit
Hardware Polyphony: 64 Voices
PC Interface: PCI
Connectors: Digital Out for 5.1(6-channel SPDIF Output), Line-Out, Line-In, SB1394/Firewire, Mic-In, Analog/Digital CD Audio In(See Details)
External Box: Yes
Remote Control: Yes
Package Contents: See pics
Special Features: DVD-Audio, THX Certified, DTS-Extended Surround, EAX 4.0 Advanced HD, DirectSound 3D more info-> N82E16829102163
$165.99
Thermalright Heatsink for P4 & K8 CPUs, Model "XP-90" -RETAIL
Specifications:
Compatibility: AMD: Athlon64 FX 3200+ (socket 939/940)/Athlon64 3200+ (socket 754) and above
Intel: Pentium-4 socket 478 3.2 GHz and above
Material: Aluminum fins with copper base(nickel plated)
Dimensions: 116 x 96 x 96 mm (LxWxH)
Weight: 0.79 lbs(360g) more info-> N82E16835109119
$39.99
Logitech X-530 5.1 Black Speaker System -RETAIL
Specifications:
Configuration: 5.1
Power Output: 70 watts RMS
Frequency Response: 40Hz - 20kHz
Signal to noise ratio: >96dB
Remote: N/A
Features: Frequency Directed Dual Driver (FDD2) satellite technology produces a uniform sound field for full, rich sound; Matching front & rear satellites deliver balanced surround sound; Dedicated center channel makes dialogue clear and intelligiblel; Dynamic, real-time bass equalization maximizes bass response while minimizing distortion; Ported subwoofer design displaces more air for deeper bass more info-> N82E16836121118
$65.99
Subtotal »$1,728.96
edit your post so that it is just a part list and not all the details about each part, b/c no one wants to read through 2 pages of that crap
Replace your AMD Athlon 64 3500+ that is 130nm with the Newcastle Core with the AMD Athlon 64 3500+ that is 90nm and has the Winchester Core. :D :cool:
