Primarily Gaming and web browsing.
$800 Max.
3) Where do you live?
San Diego, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Mobo, Video Card, Power Supply
Not reusing any parts. Only input devices, mouse, keyboard.
6) Will you be overclocking?
Not sure.
22" Widescreen 1680x1050 resolution
Next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
just gonna be using a single card, so SLI/Crossfire is not very important.
10) Do you already have a legit and reusable/transferable OS key/license?
No
Hello all. I would like to build a budget gaming PC primarily for light gaming (WoW) and web browsing. Then next year I would like to upgrade to a core i7, or whatever is out by then, build. I already bought the case I will be using, the Antec 300. Just need advice on the main components. Games I would like to play at a good framerate include Far Cry 2, WoW, and LFD at 1680x1050. Prolly won't need an SLI motherboard, since I'll be upgrading in the future. Just need something to hold me over til next year. Thanks for your advice.
$800 Max.
San Diego, CA
Not sure.
Next week
No
