Hello guys! Been lurking around since about 2009. Always liked to read and try to understand all the science behind it, but I can't seem to grasp a little more than the regular hobbyist would
Well, I am currently running on XSPC 750 RS360 build that I got just under 2 years ago. I am converting that pc into a home theatre pc and will be building a new one.
I already have the system built and prepped, but now will be adding the liquid cooling. As of right now, the build I am looking at revolves around me using the XSPC 750 RS360 in the new build as well (mainly for redundancy but also for added pressure (if I understood Martin's Liquid Lab review correctly?)) Also, I will be adding the Swiftech MCP655-PWM to the XSPC system for added pumping power.
I drew up a diagram that is actually fairly accurate in scaling. I will list the relevant gear below the image.
The tubing will be 1/2" ID x 3/4" OD all around. Would this build make sense? Would the flow be good? Any edits/changes/revisions that should be made?
Thanks for your help!
- CPU - i7 3770k @ 4.6 GHz
- Mobo - ASRock Z77 Extreme11 LGA 1155 Intel Z77
- GPU1 - EVGA GTX 780 Hydro (03G-P4-2789-KR)
- GPU2 - (will be adding another 780 in the coming weeks)
- PSU - Cooler Master Silent Pro Gold 1000W
- Fans - 120mm and 140mm Thermalright Fans
- Case - Cooler Master HAF 932 Advanced
