My friend's budget build
M4573R
Gaming mostly.
1340 with tax and shipping
3) Where do you live?
Washington
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Case, all internals, and monitor.
I can scrounge up a mouse and keyboard.
6) Will you be overclocking?
Shouldn't have to on a new build.
Something 1920x1080
This weekend.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Overclocking options would be nice for the future. No raid, firewire, or multi-gpu
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7.
What I've been thinking so far:
339.99 - Phenom II X4 + mobo
174.99 - 3x2 DDR3-1600 Mushkin Memory
139.99 - Corsair 620HX PSU
197.99 - EVGA 260GTX
169.99 - Asus 21.5"
74.99 - WD 640 AALS
Total so far: 1105.85
Thanks for the help!
1. Buy 4 GB of 1066 DDR2 RAM for ~50$...DDR3 RAM isn't worth it.
2. Get one these monitors:
http://www.shopsharksystems.com/bro...glebase&utm_medium=cpc&utm_campaign=SS1052488
Alternative monitor: LP2475w Looks like you can find refurbs for 400$
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=3120319
3. CORSAIR CMPSU-650TX 650W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005 Don't bother with a modular PSU imo.
4. Are you planning on gaming without sound? I would recommend grabbing Swans M12 for an cheap 2.1 system that is still reasonable.
With that budget you can get an i7! :p (sorry, that tidbit was required)
Now... I agree, switch to a DDR2 board and kit. ;) What case are you using? Need a rec? RC-690.
Onboard sound can be used until a sound card can be afforded. Why is DDR3 not worth it? Doesn't all AM3 boards use ddr3?
They can use DDR2 as well. DDR3 isn't worth it because it doesn't offer enough for the cost. I was talking about speakers not a sound card.
EDIT: Actually that board might not support DDR2.
EDIT2: Fuck it. Find out for yourself. If it doesn't grab 4GBs of DDR3 for ~70$
