Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Sitting around bored, decided to do a water cooling project heres the end result. Tested on a celeron 500mhz, next im going to try on my A64 3000+. Pulled it off and the proc wasnt even hot, figure if i get a desktop case this could work
Edit: so you know that is a glass with ice water in it
True, hmm... well im going to go try and find a copper container and put some artic silver on the bottom. Condensation though, is a bit of an issue but a towel should should that or some neoprene maybe.
