I am putting together my first water cooled system and I wanted to get your reactions. I was thinking about the getting Apex kit, but I had a Bonneville core that I had bought 2nd hand a while back, so I decided to just use it. Here is a run down of what I got going.
Swiftech Storm CPU Waterblock
Danger Den Maze4 Acetal GPU Block
Swiftech MCP650 Pump
Bonneville heater core
Swiftech MCRES-525 Reservoir
I rigged a shroud for the heater core and installed 2 120mm fans in it. Check out the shot of the leak test I'm doing tonight.
It's an older system (IC7 / P4 3.2 / 6800GT), so nuthin to write home about there, but I do think the Storm block looks cool! Sorry about the naked case.
