Well, that's not completely true.. The last time I overclocked was back on the good ol' celeron 300a (to 450mhz).. Anyways..
I built a new rig a few days ago (e6600 conroe) with the intentions of getting as good of an OC i could get without too much stress on the system.. So I started to experiment last night..
So being cautious I crept up the mhz slowly, 2.6ghz at first, seemed no problems, 2.8.. no problems.. Anyways, I went all the way up to 3.6ghz sync'ed with memory at 800.. 3.4ghz was flawless but at 3.6 it has just restarted the computer while running prime95. I would assume this indicates not enough voltage?
It was late so I went to sleep, but when I get home today I will try creeping up the voltage a bit more and see what happens..
As far as noob questions I have..
- What's the difference between the cpu core voltage and the cpu FSB voltage? Does one need to get changed more than the other? I assume the core voltage is the important one..
- How much of a difference is there running memory at 5/5/5/12/2T as opposed to 4/4/4/10/1T performance wise? I noticed when at 3.6 I don't know if the memory I have can do 4/4/4/1T at 800.. Or maybe I just didn't give it enough juice..
- How much power do you think is too much for memory and cpu voltage? I think I currently have my cpu voltage set to like 1.45 for 3.6ghz or so, I will probably have to go higher to make it stable if it will become stable at all. Memory voltage was at I think 2.0.. Core temp was around 36 idle and 52
- If I cant keep a 3.6ghz stable overclock, am I getting reduced performance in areas because the memory is not running at it's specified rate? (ddr2-800)
I appreciate all the help, I am a total noob when it comes to overclocking on these new platforms so any advice would be much appreciated..
Here's my setup:
intel e6600 (cooled with thermalright ultra-120 w/ s-flex 1200rpm fan)
eVGA 680i A1 revision
eVGA 8800GTX
2GB (1gb x 2) g.skill DDR2-800
raptor 150gb hd
500gb storage drive
3007fpw
silverstone OP1000 PSU
silverstone TJ-09 case
Here's my setup:
eVGA 8800GTX
raptor 150gb hd
500gb storage drive
3007fpw
