My First Real Mod
  • Thread starter Deleted member 96510
  • Start date
D
Guest
Okay everyone, this is my first real mod. It's an Antec CS200 that I bought at CompUSA for $25. I cut the window and painted it myself. Tell me what you think.
very nice, i like it a lot. the style of the window is something ive never seen before. nice job with the paint also! keep it up!
How do you like the case? I was thinking about getting the same one from compusa too..
It's not a bad case for a budget system. The part it like the least is the fact that you have to remove the top panel to remove the side panels. But for the price, i'm not complaining too much.
i like the cutout, but i would've taped or glued the window to the side panel. nice job!
I think the screws add a cool look to the plexi.It would look a lot better if it was a diferent color.But I like that window.Good job!
Thanks a lot guys. I used screws on purpose. I like the look and it leaves the option to try other things. What you may not see in these pictures is I used blue MetalSpeck paint and the black parts have a blue sparkle to it. Might I also add, I did this in the kitchen of my apartment in NYC, using an old chair as a workbench.
Thanks for the input. I'm looking forward to my next project.
Holy sh**, that is a nice mod work. The thing that caught my attention is your motherboard, I've never seen a green ABIT mobo. What model is it? Looks like it's using Rambus.
It's an older ABIT mobo. TH7II-RAID. It does use Rambus. I had it for a long time and never put it to use.....until now.
I think there was a problem with my web host. The pictures are back up now
*claps* thank god you didnt just put a square in! next time glue or tape the window though, gives it a much cleaner look. Very sexy though you have my props
