My first Overclock
rfw2003
Well here are the results of my first overclock so far. I'm running a Asus A7N8X-E Deluxe, XP2600, 512mb of PC2700. I've got the chip running at 11.5x200 with a vcore of 1.75. Has been prime stable for the last 48 hours. my case temp is 28c weither the cpu is idle or loaded, and the cpu temps are 41c idle and 45 loaded. Currently I have a SLK-900A HS with a Vantec 92x38 tornado and 4 80x38 vantec tornado Case fans. Also I am running my memory at the 200mhz as well. I'm still gathering parts for my water cooling setup and then I'll see how far I can take this thing.
How does this compare with similar setups?
R.F.
Well if you are running your ram 1:1 then I'd say that's pretty impressive. Either way , nice job :) welcome to the world that is overclocking , now be prepared to become an addict. *eye twitches*
yes I am running my ram 1:1. I'm already addicted. I want to see just how far I can go with this one and keep her stable.
R.F.
R.F.
Just don't let the addiction turn into 3am testing when you have to get up for work at 5:30am. Not like I would do anything like that :D
Well that I can't do. I drive a truck for a living so I'm only home about a week out of the month, so I only get to mess with the box very little, but as far as testing all night that is easy, because I normally sleep during the Day and am awake all night.
R.F.
