hazard_one
- Jan 17, 2007
Well i recently purchased a Q6700 and Abit IP35 Pro for my first rig since my Athlon XP 2500+.
My complete specs are in my sig and used AS5.
Pretty much I wanted to break it in about 200 hours before i started OCing. I'm using Everest Ultimate to measure temps.
Base line:
Q6700 @ 2.66 (Stock Speeds)
I'm not exactly sure how to read these temp because they have CPU, + the temps of the 4 cores. Which temps should i be looking at?
CPU/Core1/Core2/Core3/Core4:
Idle: 27/40/37/34/36 (why such a big difference between cores?)
Load: 37/50/48/44/44
How do these temps look? I think theyre a little high for my setup. What do you guys think is wrong?
Base line:
