I've been wanting to OC for a long long time, and just got to try it out recently! I've had a BIostar M7VIF MB and an AMD XP 1700+ T-Bred A for the longest time but couldnt OC cause my Biostar wouldnt let me change the stuff. So I was stuck.
I just recently bought an NF7-S motherboard, a stick of 256mb Kingmax PC3500 tinybga ram, and a 1700+ T-Bred B, with a heatsink and an 80mm fan that sounds (quite literally) like a blowdryer.
Plug it all in, and it runs normal, the 1.4xGHz that its sposed to run.
I raise the multiplier, and got it up to 16x133 and it ran like a dream, burnin'ed with Sisoft Sandra and played an hour or two of NFSU, it ran like a champ. Especially with my new ATI Radeon 9600, upgraded from a 7500! :-P
So that was all good and someone said that I should raise my FSB instead of the multiplier, that it'd run better! So I decide to do 200x11, and it wouldnt boot! Turns out I forgot the essential raising of voltage on my CPU and raised it from where it was at 1.5 to 1.7, and it booted up! So now its running 200x11, effectively 2.2GHz, at about 80 degrees farenheit. I burnined with Sisoft, played alot of NFSU, and did the tests with 3dmark. Everythings uberstable, runs great.
Anyone have any suggestions to keep it going excellent, or maybe raise it? I was thinking of upgrading my RAM to a 512 stick. Also, how far do you think the CPU will go? The fan generates ALOT of fanpower, this thing is truly a beast, it circulates so much air its not funny! I'll get the exact model when I get home..
Anyway, I thought 2.2GHz was pretty [h]ard for my first try!
