Thawaxshop
Bad Trader
- Dec 18, 2006
I did it guys
My first successful IHS romoval on a 775 soldered on chip
My L629A E6300 was the donor
First i did the norm of cutting all the silicone off the ihs, then i setup the 4 razors so they overlap each other and give pressure to the chip. then set it on two glasses (on the razors edge) so that when the solder melted the chip would fall. Then used a small butane mini torch to heat the ihs qickly and it dropped. Cleaned off the solder with my fingernail and a razor and plopped it back in. Used to idle @ 33c now down to 28-29c
