My First mod - Wireing Job
FaultySanity
2 hours, and a cut finger...and i managed to do (in my own mind) a good wireing job.
BEFORE:
AFTER:
Another pic:
EDIT: And my window isnt scratched - its just uber dusty :D
A- for the werid yellow light, lol other than that i would you did very good for first time. hope to see more :)
That does look nice. The yellow is a bit weird, but if you like yellow then it's all good. Pics of the cut finger :p
Wanna make it even better?
Cut the "labels" off the ends of the cables. You know, the ones that say "SLAVE", "MASTER".
Slip the boots of the cables down to cover the wires a little better.
I see your ATX connecotr is sleeved, but the part that shows doen't have sleeving on it. I assume you just need to slide the sleeving down to the connector a little more.
Kudos on reversing the direction of the hard drives to hide the wiring. Now d that with the CDROM and you'd be set.
Just kidding about switching the CDROM around.
very nice compared to before. i also like the yellow light bc i have never seen one before in a case. :)
Really nice man. My comp looks the way yours did before. So im gonna follow your example. Il let you know how it goes. Great job!
