Allright finnaly after saying that I was going to do this for the past year I finnally ordered the parts and constructed a 6 port 12v High/off/7v Low fan baybus. Heres some pics let me know how you like it:
Shows the inner workings from behind you can see the junction box i plug the fans into
Closeups of the junction box, shows powerswitch and indicator LED (to turn off when pluggin stuff in so theres no shorts) and also the 2.5mm audio jacks for fans
Back pic of front switch panel shows the "hard part"
Note: I had to mount the switches to an aluminum plate as the plexi baycover was to thick to mount to, then the aluminum to the outter part of the plexi cover I cut out
Let me know what you guys think..........
-Appatula
-Appatula
