I have built an ITX System for the first time.
Here are the specs.
Intel i7 2600K CPU
Adata 8GB PC-1600 C9 (2x 4GB)
Zotac Z68-ITX Wifi
Adata 120GB S511 SSD SATA3 (Drive C)
Western Digital 1TB 1002FAEX Cavier Black SATA3 (Drive D)
Pioneer 219LBK SATA 24X DVD-R/RW
Antec TruePower 550W (Cable Management)
Lian Li PC-Q08B Tower Case
Windows 7 Ultimate
I changed the 2 Lian Li case fans to Silverstone 14 cm and 12cm fans.
For CPU cooling I am using the Cooler Master Vortex Plus
The only problem I have is the clips which hold the fan on the Cooler Master Vortex Plus is coming in the way of the PCI-E slot.
I am wondering if I can use zip tie to hold the fan on the Vortex Plus as an alternative solution so that I can use a better display card for occational gaming.
Here are the specs.
Intel i7 2600K CPU
Zotac Z68-ITX Wifi
Windows 7 Ultimate
