My first ever build - Please check it out
minigister
Hello, this is my first post on the forums. Anyone I am planning on building my own computer after having my current one for almost 3 years. I dont know much about building but I have pieced together the required spec.
Motherboard: Abit IP35 Pro Motherboard - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3263080&sku=A458-1180
CPU: Intel Core 2 Duo E8400 Processor BX80570E8400 - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3574211&sku=CP1-DUO-E8400
RAM: 4G OCZ Platinum Revision - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2882686&sku=O261-8070
PSU: BFG 650-Watt ATX - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2181001&sku=B52-3004
OS: Windows Vista Home Prem 64-bit - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2864283&sku=M17-7414
GPU: EVGA GeForce 8800 GT Video Card - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3538922&sku=E145-8832
CD/DVD: Sony DRU190A 20X DVD Rewritable Drive - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3569869&sku=S167-4514
KEYBOARD: Logitech diNovo Edge - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2539615&sku=L23-7252
MOUSE: Logitech MX Revolution - http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2340176&sku=L23-7200
I already have an lcd monitor so the total comes to $1,538.88 + shipping
I could probably find it couple hundreds cheaper if I look around.
What do you guys think?
I
Well after looking at your items I will say that you are spending more money than you should on this whole setup. Let's revise this.
Gigabyte P35 Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128086 (All the same features and save some green.)
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565 (Two of these are cheaper than the OCZ and overclock better too.)
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037 (Same one but save $20)
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151028 (More energy efficient and will save you more money if you put your PC into sleep.)
OS: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488&Tpk=32-116-488 (Same one just cheaper also includes SP1)
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318 (Same one but cheaper w/mail-in-rebate)
CD/DVD: http://www.newegg.com/Shopping/ShoppingItem.aspx?ItemList=N82E16827106072 (Lite-on drives are shorter in length and SATA increases data throughput)
KB/M: http://www.newegg.com/Product/Product.aspx?Item=N82E16823126033 (Cheaper and just as reliable. However this is personal preference. Go to a store and try a few out.)
Original Total: $1518.88
Revised Total: $984.91 + shipping
Saving $500 is quite a bit of cash. Hope you like what I have shown you, and good luck on your new build. Pics, or I call shens. :p
sorry man, newwegg doesn't ship to canada :( and tigerdirect seems to be the only good Canadian site I have found so far.
Oh well sorry dude, unless you know someone in the US that is willing to do it. :( Good luck though.
lol for $50 + the purchase cash i would order the parts then forward to the land of the canucks... but then again there isnt too much i wouldnt do for $50 (keep your thoughts clean your pervs)
Check the list of Canadian retail sites in the Gen[H]ard FAQ/sticky for more options. And try to look for (some of) the parts that CptFalcon recommended to you.
