My first Dremel Cuts.
Nims
Just a few pics of my first Dremel handy work.
Nice work. Are you planning on putting a window in the top CD drive? Or is that vent for something else?
Pretty good. Where did you get that black lining that you used to cover the edge you cut.
I have a V-1000 and I've been wanting to put a cut just like that in it but I'm afraid that I'll short the wires on the bare metal.
Is this the stuff your looking for?
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=132
Hope that helps!
Nice Dremel work Nims, a pretty steady hand for a 1st time! Keep up the good work :)
I've got a 150gig Raptor ( the one with the window) up there (idea stolen from LevelLord. :) Thanks!).
And yes, that black lining is from performance pcs. It's great stuff.
I should have it all done this weekend hopefully. Will post the rest of the pics when it's done.
