My first custom water cooling loop
Mytime34
I finally finished my first custom loop:
Specs:
Corsair 600T White Case
Asus Z97-A mobo
i7-4790k (not overclocked)
4 x 4gb DDR3 (Ripjaw and Gskil)
2 x 512gb M4 Crucial SSD
Asus GTX 780 DCUIIOC
Corsair AS700 PSU
Windows 8.1
Water loop parts:
Phobya Xtreme 200 Radiator
Koolance Radiator 240mm
NZXT FS-200RB Premium 200x30mm Fan
3 x NZXT FN-120RB 120mm Fan
EK 140 Res/pump combo block
Swiftech D5 Pump
3/8 x 1/2" Blue tubing
No name flow detector and temp gauge
Heatkiller 3.0 CPU Block
Ambient water temps are 25c
CPU Temp sits around 27c
Prime 95 small tests and the temps are around 67c (+/- 3c)
The system is super quiet
nicely laid out there. i didn't have any luck with a rad above the motherboard as for my mobo didn't clear it well enough.
i have the same case and went a little different of a set up. i did a quad 120 rad on the mesh side panel and a 120mm rad on the rear exhaust. i kept the stock 200mm fans on the top and front.
my cpu 2600k @ 5ghz, idle is 20c and prime95 get to about 42c.
