This is my very first computer build. The setup is kind of overkill, since all I use my computer for currently are WC3 and online poker programs (I play multiple tables at once, which consumes quite a bit of memory). I might pick up some games in the future, though, and I'd like my computer to run as smoothly as possible. I'd also prefer that the setup is quiet, so if I include some very loud components, please let me know
Case: Antec Solution SLK3000-B ($50) or SLK3700 (~50 also?)
PSU: XCLIO 450BL ATX 450W ($53) or Enermax Noisetaker 375W ($43) (http://www.newegg.com/Product/Product.asp?Item=17-103-444&depa=0)
-Will it make much difference which PSU I choose? I'm leaning towards the Enermax one since it's supposedely more quiet.
Motherboard: Chaintech VNF4 Ultra ($88)
RAM: Corsair ValueSelect 1GB (2x512mb) ($80)
Processor: AMD Athlon 64 3000+ Venice ($146)
-I'm debating upgrading to a 3200+. Will I notice much of a difference between the two when carrying out daily tasks (WC3, poker, surfing...)? The money isn't a huge issue, but I'd still rather not go too overboard.
Video card: Sapphire Radeon X800 256MB PCI-E ($180 after rebate) (http://www.newegg.com/Product/Product.asp?Item=17-103-444&depa=0)
-I think this is way overkill for my needs, but let me explain. I need 2 DVI slots, and I already have an ATI PCI card that I can use for the 2nd DVI. So, it's either this X800, a lower-end ATI card, or the XFX 6600GT, which has dual-DVI. The XFX 6600GT costs $169, and the X800 owns it performance-wise for $11 more. Plus, this card should last me a very long time. Would you still recommend something else?
Hard drive: I already own a WD Caviar 80GB 8mb cache drive that I plan on re-using. Will it suffice? I also need to buy another ~80GB HD for storage only... any recommendations or other solutions? Should I just buy one 160GB HD that outperforms the WD? Or, should I buy a better 80GB HD and use the WD for storage? Keep in mind that I prefer a quiet setup.
Comments are greatly appreciated. I'm particularly interested in hearing input on the PSU, video card, and hard drive.
Thanks in advance!!
Edit: I forgot to include that I don't plan on overclocking.
Thanks in advance!!
