My first case build..first case mod
wookiewoof
I have been buying parts for case over the last 4 months and have got the last part..the PSU. I have now started to mod the case which you see here
The case is mid-tower which is quite small on the inside of this case
I have decided to mod this case by building a PSU box which will hold PSU and mount under the case. I am gonna cut some holes on either side of the power supply to give a little more room for the PSU and to give better airflow around the PSU
Here is the case mod in its' preliminary stage. The box will eventually be covered with aluminum sheets and painted black..maybe Metalcast Red Anodized Paint. I am gonna build a bracket to hold to 80mm fans and place that in the PSU bracket in the case.
Any suggestions on a better way to build the PSU box and any general comments/suggestions on this mod would be appreciated
that wood box under the ase looks pritty shit, no offence but i think you could have use an old case and u it down then you ould have the CDrom bays at the front to mount the fan controller and still have a propper PSU mounting place
