My First Build
n00bl3t
Hey Guys...The following will be my first build. I just got into computers and gaming and I only know a little bit what I'm doing. I'd appreciate suggestions or improvements. Maybe you can tell me if i'm way overpaying for something. I'd like to save a little more money. I wanted to cap the computer at $2000, not including keyboard/mouse and monitor, which I'll buy elsewhere. As it stands, the total is $2020.99 and I don't even have any drives yet (I'm thinking NEC DVD RW). Please, any suggestions would be great. Perhaps you even catch a compatibility problem...particularly look at video card and psu.
n00bl3t
ASUS A8N-SLI Deluxe Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16813131517
AMD Athlon 64 4000+ San Diego Integrated into Chip FSB Socket 939 Processor Model ADA4000BNBOX - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16819103529
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) ECC Registered Dual Channel Kit System Memory Model TWINX2048RE-3200 - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16820145509
Maxtor MaXLine Plus II 7Y250M0 250GB 7200 RPM Serial ATA150 Hard Drive - OEM - http://www.newegg.com/Product/Product.asp?item=N82E16822144327
Western Digital Raptor WD740GDRTL 74GB 10,000 RPM Serial ATA150 Hard Drive - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16822144366
ASUS EN6800GT/2DT/256MB Geforce 6800GT 256MB GDDR3 PCI-Express x16 Video Card - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16814121192
SeaSonic S12-600 ATX12V 600W Power Supply - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16817151025
Lian Li PC-65B Black Aluminum ATX Mid Tower Computer Case - Retail - http://www.newegg.com/Product/Product.asp?item=N82E16811112040
You can save some money by getting a non SLI board. Unless you are looking into getting another vid card.
Maybe you should look into another PS I really don't thnk you will need 600W. So maybe an Antec NeoPower which is only $116.
Keep in mind, I wanted this to be really upgradeable as i'm going to grad school and need it to last four years.
First I'll post some suggestions on saving money:
1. You really don't need an SLI board, especially if you're only getting one video card. SLI only gives about a 10-15fps gain in most games. I'd get something like the DFI Ultra-D.
2. Drop the processor down to a 3700+ San Diego, over $100 cheaper and a very minimal performance difference.
3. This is just personal preference, but I'd drop the video card down to a X800XL. Don't let 'down' give you the wrong idea though, the XL performs on par with the GT, sometimes surpassing it.
4. 2 gigs of RAM is way overkill. 1 is all you need.
5. Get this PSU.
Looks like a really great system, and very similar to what I just built. But, you could save a bit, especially on the PS, CPU and the case.
- good advice on the San Diego
- the Antec Neopower is on sale, at least for a little while longer, if you can get by w/o a 600W power supply ;)
- 2 gigs of memory is NOT overkill and is a very smart move if you can afford it
Ok on the PSU. Don't get the OCZ Powerstream 420. Get an ATX12v2.0 PSU like the Seasonic S12 you choose. You want upgradeability then that is going to be a good choice, in addition the Seasonic's are top notch PSU's, quiet, and efficent. Anyone building a PC now should be getting ATX12v2.0 PSU's for the native 24pin, and the split 12v isolating high draw items like power hungry CPu's and videocards.
Don't want to go OT here or Hijack, but..
n00bl3t, don't post too much or your n00bie tag will go away. ;)
