My first build
Odane87
im thinking of builting my first computer. something that is a good price and yet can still play most the top games (setting dont have to be maxed). These are some of the parts iv fond, can you all tell me if this is going to work for the price.
Thank you
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard
Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 65W Dual-Core Processor
Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory Model KVR667D2N5K2/2G
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Maxtor DiamondMax 21 STM3250310AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
Microsoft Windows Vista Home Basic SP1 64-bit English
Athena Power CA-2852B48 Black Steel ATX Mid Tower PC Computer Case ATX 480W PS2 V.2.2 PSU Power Supply
LG Combo Drive Black IDE Model GCC-H23NK - OEM
the price comes out to be about $735.00 if i buy from newegg.
It can be better man. Some of the parts you are getting like the 650i chipset mobo and E6300 CPU is old. Get a P35 chipset mobo paired with a E2XXX cpu and O/C this cpu. Then, bump up your RAM to 4 gigs (2x2gig) modules. 250gig is pretty small also, get a 320gig at least.
For $85 (AR) more I put this together which should be pretty beastly - 3.0 Ghz of 45nm goodness, 4GB ram, 500 GB HDD. You can easily shave off some by going with a different CPU smaller HDD or shopping around, but this would definitely last you quite some time - I don't know that the same could be said for a e6300 although I do love mine.
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC24G6400ELK
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
Microsoft Windows Vista 64-Bit Home Basic for System Builders Single Pack DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220227
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116200
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129024
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
edit: changed HDD
looks like my first build.
the E6300 is old but still good as poster above said you could get a little bester but still a good build.
On the P5n-e either buy an new NB cooler or take off the original and reapply becuase the stock sink is mounted with cheap paste and can over heat easy. The remount change my temps from 42 to 33 at idle so it's a significant difference.
Side note I have 2 of these boards and have had little issues and they perform great....for the price.
I like cheap rigs so you could drop the price on the board with this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188017
and then get a 8800gts or 9800gtx.
What is your max budget on this PC build? vsboxerboy put together a pretty solid build which although costs more than your OP at $700 something, it offer more though. Also, do you plan to overclock? I would opt to go with an 8800GTS video card already as oppose to that EVGA 8800GT card.
im trying to keep it under $800, looking at what vsboxerboy posted, i was able to change some stuff and keep others and get the price to $785 by changing to the
i think 250gb hardrive is big enough for me (i dont have alot of stuff).
and your question on the vidoe card what about this? http://www.newegg.com/Product/Product.aspx?Item=N82E16814130082
switching to this card would drop the price to $740
Yikes! Please don't get that 8800GTS 320MB card. That card is old compared to the 8800GT 512mb. The 8800GT is faster than that video card. What size monitor are you gaming at? 19"? 22?"
Since I know your budget now, here is what I would do for $700 range.
Case - Antec NSK3480 with 380 Antec Earthwatts PS for $75
CPU - Intel Core 2 E2180 Allendale CPU at 2.0ghz for $70
Mobo - Gigabye GA-P35DS3L for $90
RAM - G. Skill DDR2 800 2x2gig for $77
Video - MSI NX8800GTS 512MB for $225 ($30 MIR)
HDD - Seagate 320gig SATA 300 for $75
Optical - SAMSUNG Black 20X drive for $27
O/S - Windows Home Basic 64 for $90
Total - $729 before rebates and w/o shipping
$699 after rebates and w/o shipping
Note: cpu is slower than the E8400 cpu but, you can later O/C the cpu anyways. Or, you can pop in a Q9XXX quad core cpu later on when the price gets cheaper. The MSI NX8800GTS 512MB will give you much better performance over that EVGA 8800GTS 320MB. I listed the G. Skill RAM for $77 if you don't want to bother with rebates on the Patriots RAM.
im sorry, im dont know to much about hardware. right now i dont have a monitor i was planning on getting at least a 19"
well heres my 2 cents
case: Rosewill R220-P-BK Black 0.5mm SECC Steel ATX Mid Tower $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147074
case fan: Scythe DFS123812-1000 120mm Case Fan $6.99 (the case above only came with 1 x 120mm fan)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185052
hd: Maxtor DiamondMax 21 STM3250310AS 250GB 7200 RPM SATA 3.0Gb/s $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144456
psu: SILVERSTONE ST400 ATX 12V 2.2 400W Power Supply $46.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256032
ram: mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $47.99 - $10 mir
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146673
mobo: GIGABYTE GA-P35-DS3L LGA 775 Intel P35 $89.99
gpu: EVGA 512-P3-N861-AR GeForce 9600GT 512MB 256-bit GDDR3 $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130334
cpu: Intel Core 2 Duo E8400 Wolfdale 3.0GHz $189.99
os: Microsoft Windows Vista 64-Bit Home Basic $89.99
dvd burner: LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106073
Total: $736.90 - $10 mir = $726.90+ shipping.
just saw your post about a monitor. Keep in mind that the larger the monitor(the more pixels) and the more detailed resolution you run the tough it is for your gpu to give you good frame rates. I use a 19" ws and enjoy awsome frames in every game I play.
With that in mind check this out,
Acer AL1916WAbd Black 19" 5ms $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009091
What ever lcd you get make sure it comes with a dvi cable because not all of them do.
Aww man no monitor, thats the most important thing even more important than the PC. Hehe.
ok with the ideas yall have given me here is what iv come up with
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129035&Tpk=Antec+NSK3480
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052&Tpk=Intel+Core+2+E2180+Allendale
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059&Tpk=GA-P35DS3L
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148316
Video: EVGA 512-P3-N861-AR GeForce 9600GT 512MB 256-bit GDDR3 $149.99
http://www.newegg.com/Product/Produc...82E16814130334
RAM: mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $47.99 - $10 mir
http://www.newegg.com/Product/Produc...82E16820146673
for a total of only $623 before shipping and taxes. TY for all the help
sence i dont have a monitor just yet i was wondering, can i use my laptop(15.4") as a temp monitor
Ho crap, that build looks good dude. Goodness. All you need is a decent monitor now. How much are you willing to spend on an LCD now? That 19" LCD that hossdaddy listed is pretty good for $170 or...if you wanna go bigger, get this Acer AL2216Wbd 22" for $220. I feel go for a bigger LCD because it's not often you upgrade a monitor as much as a PC upgrade. I did this before and was not satisfied. I went from 20", 21" then 22" and then 24" and now a 28".
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094
BTW, maybe you can just buy a real cheap CRT monitor just to get you by until you can get a more decent LCD later on.
I still would go for 4 gigs (2x2gig) RAM though over 2 x 1gig. Its pretty cheap that it's worth it. This way you don't worry about a memory upgrade later especially with a 64bit O/S. Plus, 2 sticks of 2 gig is better than having 4 sticks of 1 gig modules.
If you are gaming, surfing, ripping movies music etc you will be more than fine with 2 gigs, you have 4 ram slots and can easily upgrade later. As for that cpu yes it is highly overclockable but it only has a 1 mb cache which might hurt you in gaming. I would reccomend the e4xxx series like this instead,
Intel Core 2 Duo E4500 Allendale 2.2GHz LGA 775 65W Dual-Core $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115031
This series also overclocks to the same range but with twice the cache. I think most of us here will agree with me on that. Check out tis article for reference,
http://www.tomshardware.com/reviews/cache-size-matter,1709-8.html
The NSK3480 won't cut it, as it's designed to support microATX motherboards. If you want something similar, there's the NSK4480 or the Sonata III.
And the amount of L2 cache in a processor isn't a deal-breaker, especially if you're considering overclocking.
Does cache size really boost performance? @ Tom's
Influence of L2 Cache Size on Conroe Processors Performance @ XBit
UT3 Review: Cache Scaling: 1MB, 2MB, 4MB @ AnandTech
2MB or 4MB Cache? @ AnandTech
Having said that, any of the above recommended processors are good choices.
*Sigh. and I knew it was a MicroATX case also but did not see its only compatible with MicroATX mobos..
TY for everyones help, iv change a few things and i think i have a final set thatt im going to build,
SIGMA La Vie LBNWBP Leather Brown SECC Steel ATX Mid Tower Computer Case 500W Power Supply $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16811226013
Intel Core 2 E2180 Allendale CPU at 2.0ghz $70
Gigabye GA-P35DS3L $90
SAMSUNG Black 20X drive $27
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card $175
Maxtor DiamondMax 21 STM3250310AS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive $55
http://www.newegg.com/product/product.aspx?item=N82E16822144456
WINTEC AMPX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory $39
http://www.newegg.com/product/product.aspx?item=N82E16820161030
For a total of $620 before shipping and taxes
oops, yeah i changed the OS in my wish list to the SP1
and the ram i found was only $38 for 2gigs and the one you linked was $48 and after reading reviews from people the ram i found seems to be better for the price.
I recommend that you reconsider your case/PSU selection. Namely, I don't trust that power supply.
If you want a relatively inexpensive case/PSU combo, choose one of the Antec combos that I've listed earlier. Each case has one of the reliable EarthWatts model PSUs.
If you plan on overclocking the E2180, get a better HSF like the AC Freezer 7 Pro or the XIGMATEK HDT-S963.
