WarlordOne
- Mar 14, 2006
This is my first build and for it I chose the SFF Aspire X-Qpack because the number of features it has as well as the glowing reviews. Since the first case came in dented Newegg sent me another one courtesy of UPS. It's been about a month now and no one has called me back about picking up the first case. In another month I'm going to use it for a second project.
As far a building a PC it was far easier than I had hoped. The hardest part I'd say was trying to make all the cables fit in nicely.
Here's a quick breakdown:
$69.00- ASPIRE X-QPACK Black/Silver (for 2 )
$82.00- Asus P4P800-VM MATX motherboard
$42.00- CT-479 adapter
$free- Celeron M 360 1.4 oc'd to 2.4Ghz
$free- ZipCD DVD/CD-RW (from my old AMD K6-II PC) modded and painted black
$138.00- 2 Gig (2x1Gig) ST DDR3200 2.5cas memory
$104.00- Maxtor 300GB SATA II 7200rpm 16MB HDD
$10.00- 3.5" USB 2.0 Card Reader
$0.99- Firewire card
total=$445.99
s/h was about $20-$25 total, no tax.
I still need to pick up a vid card for this machine but that will be determined by what I want to do with it (dvr vs gaming) and that depends on if I'm building a 2nd machine.
Pics:
Qpack exterior:
A peek inside to show how I manage the cables, very important in a windowed case. Originally I had everything ziptied to the case but it was impossible to remove the motherboard tray without cutting every ziptie. Now I'm using cable clamps which allow me to release the wires without cutting/unplugging everything. Also notice the rounded IDE:
Face, temps are with the fans at 40% thanks to speedfan:
Here you can see the DVD Window mod which is lit by a red led and my Sony DVD burner currently charged with all the DVD burning duties:
Right side showing DiamondMax10 and Asus heatsink:
2Gigs SuperTalent Mem @ 2-3-3-6; Stock 120mm casefan modded to use 3pin fan header -allowing it to be controlled with speedfan.
Wire management on the right side; faceplate header wires twisted (because I think it looks good), HDD temp wire, round IDE, card reader and front usb cables.
That's about it. After reading many reviews I just ordered a New DVD burner- LITEON 16X DVD±R Burner W/LS, DVD-RAM Model SHM-165H6S. As far as video cards go If I end up building another Q-Pack then this one will get a good DVR card and the other one will end up with a EVGA 7900gt. If that doesn't happen I'm thinking of the AIW x800xt AGP card or maybe the 7800GS and a PCI DVR card.
total=$445.99
Pics:
Qpack exterior:
