I posted this 4 or 5 months ago, but then had to delay my order. Now, I'm ready to go again. I'm really excited about this - my current rig is almost 8 years old, so I could pretty much build a chunk of lead and it would be a heck of a lot faster. I live in Nashville - no Fry's, only best buy and circuit city.
This is my first build. I've changed out graphics cards, fans, hdd's before. I'm more afraid of software related stuff (bios flash, what's that?) than the hardware. Budget is ~$700
This is going to be a gaming machine primarily, but it will also be doing some video and music processing, cad, photoshop, sketchup. I don't plan to overclock right away, but would like the option later on to stave off obsolescence (my current computer is 7 years old - I tend to keep them for a while). As a noob, I need something that overclocks easily and is stable - the less mucking about with bios flashing and manipulation the better. I don't plan to do crossfire or sli. I want firewire support, and would like esata for a future external hdd for video storage. I don't plan to do raid. I play cod2 and nothing else, but that's only because my current machine can't run anything newer than that. Would like to run cod4, 2012, the latest stuff, at good framerates. My monitor is an older 20 inch Sony trinitron CRT.
Anyway, here's the list:
On hand:
Case: Antec 900
PSU: CORSAIR CMPSU-650TX 650W
Going to order:
Mobo: Gigabyte GA-EP45-UD3P - I've had the hardest time selecting a mobo. I'm still not sure this is the one. The dual bios sounds like a good thing for a newbie to have. Again, I'm most concerned about stability/dependability out of the box. If I have to start spending gobs of time rooting out problems, I'm not gonna be happy.
CPU: q6600 - this seems to be easily oc'd on air. On Tuesdays and Thursdays I lean towards the e8400 as a better cpu for gaming, since I don't multi-task that much.
Mem: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) - this was recommended as a good mem for oc'ing
Vid card: Visiontek Radion HD 4850 - again, has gotten good marks around here. My only hesitancy is the reported extreme heat. My monitor is an old Dell Trinitron Ultrascan 20" crt (don't plan to upgrade the monitor anytime soon). With this size monitor, would it make any sense to get the 4870, or would that be a waste of money?
HDD: WD Caviar SE16 WD6400AAKS 640GB - generally recommended as fast and dependable.
OS: Leaning towards vista 64-bit, as it supports all that ram I've got (but I'd probably have to leave behind those old games(tribes 2) and applications (word 2000)).
HS fan: Xigmatek HDT-S1283, because it was recommended to me. Don't know anything about heatsink fans. Willl probably have to add this later to save on $$.
Optical drive: Samsung SH-S223F
I'm open to any suggestions or conflict warnings about any of these, or anything else I'm missing.
Thanks!
On hand:
Case: Antec 900
Going to order:
Thanks!
