Vtecaddict
- Jun 25, 2005
Earlier this week I decided I was just going to go ahead and try to build my own setup after no one I knew could or would help me. I was looking to spend $1200 or less, but with everything I ran over. If anyone has any suggestions or criticizm then let me know, the more comments the better. I'll be using this computer for schoolwork/listening to music and gaming on it alot. TFT/WOW/HL2 etc. . I do not plan to OC. Could you guys also check to make sure everything is compatible and I have EVERYTHING needed to run this setup
Case - Will the power supply and fans that come with it be enough?
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140025
Ram- Which one would you go for? Will both work w/my setup?
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-21
or
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-34
HD-
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100576-1
CPU- This is where it gets iffy... i was going to go with a 939 be it hammer3500+ or venice 3500+ with an ASUS deluxe($170). Then I found this 754 and I figured what the heck it seems like it'd be better deal.
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80719-R
mobo-
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=240411
keyboard/mouse- Might just get a nice 30$ microsoft mouse and get a 5$ liteon keyboard
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=211112
Monitor - at least 17" LCD with DVI
Option #1:http://www.newegg.com/Product/Product.asp?Item=N82E16824163129
Option #2:https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=231635
Speakers
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=365000
DVD+CD drive
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=172622
Video Card - Is this overkill?
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=322688
Thats it and thankyou in advance!
or
HD-
mobo-
Speakers
DVD+CD drive
