Hockeytyme
- Nov 1, 2013
It was my first build and overclock... let me know what you guys think
The Parts
Drain Ports
Wire Overload begins
AquaComputer Backplates
Aqua Computer water blocks for Titans installed
Motherboard Blocks installed
RAM, Video Cars and most of the wiring all installed
Filling the loops
KyroConnect 4-Way connector
Up and Running!!
Nearly Finished product
How does is run? Fire Strike 6th overall
Fire Strike Hall of Fame
Special Thanks to Joe over at FrozenCPU for all the help with the cooling on this beast!
Parts List:
Case: Corsair 900D
Power Supply: Cooler Master Silent Pro M2-1500W
CPU: Intel i7-4960X Extreme Edition LGA 2011 Processors BX80633I74960X
RAM: x2 Corsair DOMINATOR Platinum Series 16GB (4 x 4GB) DDR3 DRAM 2133MHz PC3 17000 C9
Motherboard: ASUS Rampage IV Extreme LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX
GPU: Quad SLI EVGA GeForce GTX TITAN SuperClocked 6GB GDDR5 06G-P4-2791-KR
Main Drives Raid 0: x2 Samsung Electronics 840 Pro Series 2.5-Inch 512 SATA_6_0_gb Solid State Drive MZ-7PD512BW
Storage Drives Raid 1: x2 HGST Ultrastar 3.5-Inch 4TB 7200RPM SATA III 6Gbps 64MB Cache
ASUS Xonar Phoebus ROG Gaming Soundcard Set
ASUS Computer International Direct Blu-Ray Writer BW-16D1HT
Watercooling and Cableing
4x Aquacomputer Kryographics GTX Titan Full Coverage Liquid Cooling Block - Acrylic / Nickel Plated (23561)
4x GTX Titan / GTX 780 Backplate - Black
EK ASUS Rampage IV Extreme Full Board Cooling Block Kit - Acetal + Nickel CSQ (EK-FB KIT RE4 - Acetal+Nickel CSQ)
EK Supremacy Universal CPU Liquid Cooling Block - Clean Full Nickel (EK-Supremacy Clean CSQ - Full Nickel)
EK Single 5.25" Bay Reservoir w/ Dual Serial DDC 3.2 PWM Pumps Installed (EK-BAY RES Dual DDC 3.2 PWM Serial (incl. pump))
EK D5 Dual CSQ Pump Top - Acetal - Black (Laing D5/ Swiftech MCP650/655/655-PWM) (EK-D5 Dual TOP G1/4 CSQ - Black Acetal)
2x Alphacool VPP655 Variable Speed Pump w/ RPM Monitoring - Single Edition
2x Black Ice SR1 Low Air Flow Optimized - 480 Radiator - Black
2x EK-MultiOption RES X3 250 - Liquid Cooling Reservoir (6 Total Ports)
4x Bitspower SLI / Crossfire Multi-Link Adapter Pair - Silver Shining (BP-WTP-C47)
24x Bitspower Ultimate G 1/4 Thread 1/2" ID x 3/4" OD Compression Fitting - Silver Shining (BP-CPF-CC5)
10x Bitspower G 1/4" Silver Dual Rotary 90° Adapter (BP-90R2)
15 feet PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD - Clear (PFLEXA-34)
1x PrimoChill Vortex Clear PMMA Visual Flow Indicators - Blood Red Faceplates (FI-VC-BR)
4x Phobya LED Flex Light 36 Count SMD LED Light Strip - 30cm - UV (83126)
x7 Cougar 120mm x 25mm CFD Series LED Fan - Red LED (CF-D12HB-R)
x6 Cougar 120mm x 25mm CFD Series LED Fan - Blue LED (CF-D12HB-B)
Cougar 140mm x 25mm CFD Series LED Fan - Blue LED (CF-D14HB-B)
PrimoChill Intensifier™ Transparent – Coolant Dyes - 15mL - UV Red (IBT-UR)
Vandal Resistant Style Latching Switch Cable Harness - CUSTOM Blue Illuminated Vandal Resistant "Latching" Switch - 22mm - Silver Housing - Ring Illumination
Red Illuminated Vandal Resistant "Latching" Switch - 22mm - Black Housing - Dot Illumination
Bitspower Adjustable Aqua Link Pipe II (41-69mm) - Silver (BP-DG14AALPII)
XSPC G1/4 Male to Male Extender - 5mm - Chrome
Bitspower G1/4" Mini Valve - Silver Shining (BP-MVV-SL)
Bitspower G1/4 Male to Female Extender - 40mm - Silver Shining (BP-WTP-C64)
120mm Black Fan Grill
Blue Illuminated Vandal Resistant "Momentary" Switch - 22mm - Black Housing - Ring Illumination
Mod/Smart Kobra SS 6-Pin PCI-E VGA Extension Cables - 24" - UV Red
PCI-Express PCI-E x1 Extension Cable Riser - 7"
Mod/Smart Kobra SS 24-Pin Motherboard Extension Cables - 8" - UV Red
Mod/Smart Kobra SS 8-Pin 12V EPS Motherboard Extension Cables - 8" - UV Red
Mod/Smart Kobra SS 8-Pin PCI-E VGA Extension Cables - 16" - UV Red
Mod/Smart Kobra SS 6-Pin PCI-E VGA Extension Cables - 16" - UV Red
Bitspower G1/4 Male to Female Extender - 30mm - Silver Shining (BP-WTP-C63)
Lost of other random cable extensions and such
The Parts
Drain Ports
Filling the loops
Up and Running!!
Parts List:
Case: Corsair 900D
