My first ATI purchase gone bad. Please help
PacknHeat
This is a brand new Sapphire card from Newegg.
Also, first ATI card.
The card didn't detect my monitor as a dell p991, but I went in and manually told it to load that specific drive. I changed it from 800x600 to 1024x768 then stretched the screen to fill in the black boarders.
Now when I do a normal reboot it may be fine or it may go back to having black boarders with a really really bad refresh rate. I go to monitor's settings and they are the way they should be.
To fix the problem, sometimes I change the res back to 800x600 then back to 1024x768, sometimes I have to change the refresh to 60Hertz then back to 85Hertz. Sometimes this works, sometimes it doesn't. Sometimes I have to reboot several times to get one of the above methods to work. If all is fine, then it stays fine until I reboot again or maybe after 3 good reboots. I even updated the drivers to 3.9, but it did not help.
Does this sound like a driver issue or borked card?
Hello,
What video card were you running in the machine before. I would try downloading driver cleaner and then uninstall all drivers. Then boot into safe mode and run DC using the ATI filter and while your at it you might as well clean the cab files as well. Afterwords install the latest Catalyst drivers. 4.4 are the latest but 4.3 seem to have alittle better performance. Good Luck!
Zachary
For me the 4.4's fixed some visual anomolies in a couple games and allowed me to get a little higher overclock without artifacts.
ok in your advanced properties there are 2 places to set your refresh rates. You have to look under the display settings and then check the moniter box wich will open up anouther set of options. click the use ddc information then if that info is right then click the monitor refresh rate over ride to what you want this should solve your problems
hope this works
I'm having the same problem. Screen gets set to 60hz rather that 100 randomly when I reboot. Have to change the resolution to 800x600 then back to 1024 to fix it. I'm using 4.3's, guess I give the 4.4's a try.
