That seems right. The CPU test is supposed to be that way, don't worry. The best you'll get is 2 FPS or so. I was worried too when I first tried it.
I get slightly less than you do; the quad-cores bench better.
I just got 3dmark06 to see what my score would be and i got a 11829
How is this? If i still had my 8800gts 640mb what would my score be? On the CPU test i got 0fps, it was so laggy. I left every setting at default.
Vista x64 must be WAY slower then XP x32 because we have the same CPU and Vid card overclocked (check sig) and I scored a 14476 yesterday
Yes, processor speed plays a pretty decent role in 3dmark. I'd also wager that faster memory would help a bit too. If you want, you can fiddle around with overclocking as it helps a great deal. With the set up in my sig, I get roughly 11k 3dmarks so I'm sure if you do a bit of overclocking, you'll get a higher score with ease.
I will post my score in here as well...
8591
I have
two 7900gs at 600/800
e6600 3.0
4 gigs ram
Does that score seem about right?
Yeah overclocking would give you a higher score, though I doubt it would help much in most games. I got 12.3k with an e4500 clocked to 3ghz and an 8800gts.
I know nothing about overclocking, I think Id rather stay away from it since it voids the warranty.
wanna know a secret....
The manufacture can't tell if you have overclocked or not as long as you have not done any volt modding or anything like that. As long as you are o/c'ing your cpu through the mobo bios and using a program like rivatuner to o/c your vid card they have no way of tellingCheck out the overclocking forum here and read the stickies and go from there!
If you are curious, I have the 8800 GTS 640 and I pull about 12,500 on it. I have the same processor as you, so that would likely be about what you would get.
I have it Overclocked to 675/2016 though. Fry's has them on sale for $350 after rebate, so I may pick up another for Some SLI Goodness, kickin it with 1.28 GB of Vid Ram !!!
http://service.futuremark.com/compare?3dm06=4650125
I doubt it. Overclocking a GPU doesn't raise fps that much. The g92 GTS is faster than the GT which is faster then the g80 GTS so I don't think overclocking could raise the performance that far.
You have 12.5K because of your CPU. I believe with a G92 GTS it will be close to 14K if you o'clock a q6600 cpu along side the gpu. I wouldn't buy a G80 GTS over the G92 one even if its cheaper.
And for someone looking to SLI well right now the Crossfire 3870 scales the best out of any card on the market at the given price.performance ratio.
Just my 2 cents.
Videocard: 8800GTS 512--800/2000/2200
I have a question about that 2200. What is it? My memory clock doesn't even go past 1460 in rivatuner...
Shaders
