My finished pc (long time building)
almostgfx
Ive finally finished modding mine after years and years.
If anyones seen it before it then you'll notice all the changes. Very latest changes are i cut black hard plastic stuff on the floor and over the bays to cover everything up and make it look all smooth and sleek. I was originally going to cut acrylic to do this but i had a hard time getting it to fit so i found some very hard plastic which was almost the same. Removed all the cables with the atx removal pin and attatched cable combs and changed all the red leds to white leds to make everything stand out a lot more! Any feedback you have for me would be awesome. Im finally happy with how this looks.
System Specs:
Corsair Obsidian 650D| H105 |Dominator GT 16GB | Force GT 128GB SSD|2X500GB HDD'S|240GB HYPERX 3K SSD| Windows 7 64bit|AMD Phenom II x6 1090t Black Edition 3.20Ghz|Asus Crosshair IV Formula DDR3 Motherboard| MSI Radeon 290x 4GB |
Quite Pic heavy but...
before!
And now
Great job
But I MUST take a point away
I understand an ASUS motherboard, and the Corsair gear is great.
But the lone MSI product, sigh.
j/k, excellent job.
If this is a 650D, then you made a great choice. I LOVE MINE. I have yet to even think about buying a new computer case since I got it. It's perfect in every way.
BTW, the USB3.0 cables are dated, and you can get an adapter that will convert the male ends to a mobo connector, thats what I did and it works good.
Your color combination is perfect. Wow, did that work out great, cheers!
That is really clean looking, nice work man.
I like the cable sleeving and wire management. Nice touches with the red accents.
Sweet build, I've never made anything that looked nearly that good
Great build, what did you use for the 3.5 drives to fit in the 5.25 bays?
Hey everyone thanks for the comments.
With the 3.5 drives into the 5.25 inch bays i used these.. Scythe - Anti-Vibrations HDD Mounting Kit - Hard Disk Stabilizer 2 from amazon.co.uk
With the HDD wires i cut a piece of acrylic to hide the wires in the bay but i just used l shaped connectors to the HDD (i forgot official term) and then just feed them down and cut a hole where the backside of the case is (non windowed side) so all the wires could go down there i mean this is a very very messy pic but see if you can sort of see.. on the very far left.
jcagara08 the cables are corsairs own braided cable kit in red. The only mods i did to them were used the atx pin to remove the PCI-E cables to add the cable combs to them
Heres a few i just quickly snapped for the bays for those who are interested.
Also on this build ive had to swap out the motherboard as it broke a few weeks after :( but now replaced with the Asus Crosshair IV formula-z.
Thanks for all the comments so far guys, anymore questions just fire them here and ill do my best to reply
