My fileserver is :(
Bbq
King of Charts
So I have a box that I store files on, and lately it's been bluescreening. I have the minidumps, but I have no idea how to read them. Win 7 64 bit, some amd x2 processor, matx asus board, and I forgot the rest.
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\bbq\Desktop\092910-34507-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02817000 PsLoadedModuleList = 0xfffff800`02a54e50
Debug session time: Wed Sep 29 17:40:40.468 2010 (UTC - 7:00)
System Uptime: 0 days 0:57:45.574
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 109, {a3a039d89418b5af, 0, 9cb599bdd34b010a, 101}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : ntoskrnl.exe ( nt+71f00 )
Followup: MachineOwner
If there's information you can get out of this that tells me what I should do to fix the issue, please do tell. The box runs headless and pulling it will basically mean I have to take the rack apart, so I'd prefer to find a solution before tearing it down
The salient feature of that dump is the line "Bugcheck 109".
Error code 0x109 is CRITICAL_STRUCTURE_CORRUPTION; not too helpful on its own. Try testing your memory with memtest86+ and updating all drivers.
