My fan setup...recommendations
reaver
Sorry for the rather large bottom half...mspaint :\
Back = Exhaust = Out
Front = Intake = In
Side = Intake = In
Positive pressure = Good = Less Dust
always want more air going into the case than out.
Well at least thats what i know :p
you have nothing to lose, and possibly something to gain by experimenting. swap directions on the fans. generally, tho, balanced airflow works best
Front = Intake = In
Side = Intake = In
I thought it was the other way around. More exhaust will balance out anyway because of a loss of air inside the case. Plus if there is more cool air comming into the case than hot air going out, wont it start to send cool air out and not all of the hot air?
more air out means you'll get dust in all the crack and crevices of your case, cause the airflow will be negative pressure
