Brian Boyko
[H] Consumer Editor
- Sep 27, 2005
Okay, wanted to let you guys know my experiences with the Qpack:
1) The power supply doesn't suck. It's not a super duper power supply, but it's got more than enough amps on the +12v rail to supply me with the power I need to do some basic gaming stuff. SLI? I could probably manage it, but I've got more than enough juice for my processor and video card.
2) The windows are cheap plastic - while that helps keep the weight down, it also means that they scratch VERY easily. Already they're scratched up and I'll either have to buffer them out (if I can figure out how) or replace them.
3) There is enough room in this case for a GeForce 6800. I do not know if there's enough room for a 7800, but there is a bit of length left in the case.
4) The 120mm chassis fan is a little noisy but it does a good job of keeping the case cool.
5) There's enough room in the chassis to -easily- install parts.
6) Yes, the case is thin aluminum - that may be "flimsy" but it also keeps the case light and heat dissapating.
I think it's a good case and if you're mindful of the windows or are willing to replace them, it seems like a very good SFF even with the stock PSU for most operations.
Now to get my decals.
