My first OCing experience with a CPU, extremely happy with the results so far
I got an Intel 6400 not so long ago, to experiment with the BCLK OCing, I was going to grab a used 3770k/2600k + Mobo setup but couldn't find a mATX mobo since all people use ATX for some reason.
You save around 80$ in Canada by buying 6400 instead of the K part.
Firstly, got a MSI Mortar Z170 and i5 6400 with a H60. Plugged it in and was easily able to get it at 4.4 Ghz around 1.35v, It would boot fine at 4.5 but wouldn't stay stable during stress test. It was stable at 4.5 @ 1.4v and I learnt about Vdroop and my CPU really only needed 1.35 to be stable but my mobo didn't have LLC.
Disappointed, I went to replace my Mobo and thought that I should try another time with the CPU since 4.5 ghz is good on a 2.7 ghz chip but maybe i could get better silicon lottery.
Returned the combo and got an ASUS Z170m Plus + 6400. It ran very well with 4.6ghz @ 1.3v and i just finished testing it at 1.34v / 4.7 Ghz (LLC lvl 6). That's almost 75% OC which I am pretty impressed with.
I am using OCCT 4.4.2's 2 tests to check for stability and my max temp was 82 with just OCCT and 83 with Furmark + OCCT linpack dumping my r9 290's heat into the case.
If i had a well ventilated case, I couldve got better temps with a similar priced AIR cooler but I am not sad with my H60 so far. I am using a Bitfenix Pandora which is sexy as fuck, so the tradeoff is worth it.
I am planning to Delid my CPU sometime later if I feel comfortable - as I read it drops temps quite a bit in majority of the cases.
