my epox 8rda+ died today quick ?
xaeniac
I am putting a KT600 via chipset in my pc to replace my nforce 2 mobo that just died. I know that is recommended that I format, but is it ok if I do not and just install the new board and drivers? BTW the OS is XP Pro
XP will not boot, unless you do some hocus pocus that people talk about but never works.
Back up your data and format. It's easier.
..you can do a repair install of xp , but I think you will lose anything that is in your 'My Documents' folder if it is located in its default location ... and I think you will have to reinstall all your programs and games , tho the folders would still be in program files.
actually this stuff doesn't go away .. it goes into the adminstator's documents and settings ... i figured that out when I accidently thought i lost everything
ah ..cool ..handy tidbit to know ..thanks :)
Yea back up everything and do a fresh install. I got away with swapping boards 1 time. It wasnt really a swap of chipsets, just boards. (went from a A7N8X Deluxe to a A7N8X-E deluxe). Its basically the samething.
Even if you have seen people get away with it, i wouldnt try it. It might boot up, run this and that, but there will always be something wrong. Fresh install is the only way to go.
I replaced the board and it booted XP with no problems whatsoever. Found all the drivers and everything is working without a hitch.
