my emachine computer is busted
hello my name is tony im new to the forum
basically im having a problem my my emachine computer.
for some reason it has stop sending a signal to the flat screen monitor
I believe it could be the video card since ive unplugged all the cables and put them back in
i would greatly appreciate any help thank you
Need a bit more info to be of any help.
Do you have another monitor that you could plug the PC into to determine if it is your display? Did you change anything (setting or hardware wise) before the display stopped working? What, if anything, comes up on the monitor (e.g. No input, out of range)?
Is the emachines running off a separate video card? Try removing the video card and run it off the integrated video on the mobo.
Do all the fans and HDD spin up? eMachines are notorious for crappy PSU's that go out and often take the motherboard with them.
