My E6600 OC Results
fusionrs
CPU Model: C2D E6600 OEM
CPU Clockspeed: 3.0ghz (333mhz X 9)
CPU Voltage: 1.288
Motherboard: Asus P5B Deluxe
BIOS Version: 0507
Heatsink/Block: Scythe Mine w/AS5
Fan: 100MM on Scythe 120MM on back of case
Idle/Load: 39-40/46-50 averaging 47 on load.
Ambient: 26.5
Utility Reading Temps: Core Temp/Speedfan/Asus Probe and AISuite, Priming using CPU Stability Test and Prime 95.
Around 40k in 3DMark01se, SuperPI to 1M in 16s. :eek:
This thing is a beast! I'm hoping to get 3.2-3.4ghz stable and be done. The machine is insanely fast!
Rig is in the sig...
Nice results! How much of an improvement are you seeing over your old system?
It's really incredible to be honest with you. So much of a difference. I started using my old comp a little while ago and became quite agitated at its slow speed. :eek:
sparks said:
fusionrs what week is yours?
sparks
I believe it is a 24 but I'll double check when I get home.
My buddy with an E6400, P5B, Mushkin PC6400 is having a hell of a time OC'ing. He can't get above 2.5 stable. We think it's a combination of his NB getting too hot and his PSU not being able to pump enough power.
how can you boot with the bios 0501 ? i tought only 701 and above were needed to boot with C2D ?
You are thinking of the wrong board. The board you are thinking of is the P5WDH which is 975 chipset and does require a newer bios to boot.
The P5B Deluxe works right out of the box no problems.
