Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
anyone know where i can get a new 1 cheap? i was cutting a window in the top of my case when the thing randomly died lolz. It got all hot and made a sizzeling sound.
some help would be greatly appretiated
Pepboys usually has a kit like this, but without the flexshaft, for $18.
Additionally, www.harborfreight.com has a similar/identical tool for $15 + $8 S/H, but your local Harbor Freight may have one. Search for Variable Speed Rotary Tool.
Also, I want to get some dremel discs. Which ones are good for case cutting?
You can pick up a "Craftsman Rotory Tool" dirt-azz cheap at your local Sears. I have the 5 speed variable model, it has lasted over a year now. Go check em out.
If you bought a cheap one in the first place, thats probably the reason it died......if you bought a dremel branded dremel then you probably can fix it..... Oh and if they do die, that means yer not using it right
I have broken 2 in the past. I have horrible luck with dremmels. One the damn thing stoped working a few days after i got it. And then that one stopped working about 2 months later. I took that one apart and it was the trigger system that broke. I have yet to contact dremmel and see if i can get a replacement from them. I have actualy been very disapointed with how they break so often in my hands (i am not doing anything to break them, and I have been using dremels for over 7 years). Right now I am using my brothers, And His has even stoped working in my hands. Kinda the same thing that yours did, We just took it apart cleaned it and put it back together and it works great again (why couldnt mine of been that easy to fix)
yah dood i got a router for doing big cutting jobs such as cutting big ass windows and such also i picked up a 73mm hole saw so i can cut perfect holes for 80mm fans ill post some pix of my ghetto modded case i did in like an hour heh
ok screw it im lazy and dont feel like opening photoshop to resize pics
when i finaly get off my ass i might even go take a shower.... nah aint happening
well really both ... yay!! i solved my dremel delema i baught a new 1 at home dipot yay!! now i can almoast start my new case......... that is whenever i decide on which 1 to order
Just wondering are you going to have a memorial service for your old one??? i am sure it has treated you well... and in its time of need you were there for it and there was really nothing you could do for it.. So pull out a nice shoe box like name brand shoes Puma Nike you know... put some nice Velvet in there... give it a nice place to rest like under a shade tree.... i think it will like that... may he rest in piece
o as we walk through the vally of the shadow of death, thou shalt not be afraid for death is only a new beginning thusly what we have accomplished in life echos in eternity.......
ok i think i got a little carried away.....
