my DFI rma...
Jason711
in here im going to post my experiance with rma'ing my DFI board.
to tech: (7/26/5)
hello, i have a mobile 3400+ clawhammer on a nf3 250gb (socket 754). the board boots up and recognizes the processor fine, however it will not let me adjust any of the voltages. this prevents me from installing windows. i have updated to the latest official bios. what would be the cause?
thanks,
_____________
from tech: (7/26/5)
That board does not support mobile processor for one thing. Some work and some will not. 9/15 bios seemed to work ok for some users trying to run a mobile back last fall of last year. Don't know if that was ever an official bios or not and may always have been beta and you will have to perhaps google a download of it up to try it. It is beta and you need to know that any failure will be your baby as the cpu is not supported anyway no matter how many folks tinkered around and got a mobile to run and that includes me. Thank you.
____________
to tech: (7/28/5)
i installed a 2800+ newcastle into it and it still will not let me adjust any of the voltages, although it does boot up with 1.49v at the vcore. i am still unable to install windows, i also have the latest offical bios. i believe i have a bad board. how do i start an rma?
____________
from tech: (7/28/5)
Sir:
The information I will list for you below is necessary in order to process any rma. Please collect the information below and INSERT into this email and FORWARD the entire email to rma@dfiweb.com to begin rma processing. Thank you.
When you email or call DFI, please provide these information:
Product model and revision if known. ( Usually shown as R. AXX or similar on stick-on with barcode on PCI slot).
Mother board serial number. On end of box board came in and also in various places on the board.
Place where you purchased this product.
Invoice number or Receipt number from your vendor.
____________
from customer support: (8/5/5)
Please fill out the attached form and e-mail/fax it back to me with a
copy of the sales receipt for the board and I'll issue you a RMA number.
Thank you.
Best regards,
__________
to cs: (8/8/5)
ordered from mwave.com, the invoice number is XX-XXXXXXXX
motherboard s/n is xxxxxxxx
___________
from cs: (8/8/5)
> Thank you for the RMA form. Could you please attach your sales
> receipt/order confirmation again? The one that you've provided needs
a
> log-in name and password.
> Thank you!
___________
to cs: (8/8/5)
haha.. sorry about that. here is an attached image of it.
___________
from cs: (8/8/5)
Thank you for your prompt reply. This one looks great.
Your RMA number is xxxxxxxx. Please keep all your accessories and
obtain a tracking number for the package in case it gets lost.
Thank you.
Best regards,
___________
to cs: (8/16/5)
i have never sent DFI an rma before, is there any way i can check on its status?
thanks,
___________
from cs: (8/16/5)
We've received your board last Wednesday, the 10th. We'll try to send
it back to you before the end of this week.
Thank you for your patience.
Best regards,
____________
to cs: (8/17/5)
that sounds all right. will i be notified of the shipment?
thanks again,
____________
from cs: (8/17/5)
I'll e-mail you a tracking number once it's sent.
____________
to cs: (8/23/5)
was just wondering if it has been sent or not.
____________
from cs: (8/23/5)
Your UPS tracking number is: xxxxxxxxxxxxxxxxx. You should be able to
track it by tonight.
Best regards,
____________
to cs: (8/31/5)
thank you for your help throughout all of this. however, upon
getting the motherboard back i have another problem. the voltages on
the board will not stay after the computer is shut down. it is then
that they are no longer adjustable. since i have already sent the
board in for an RMA, how can this be delt with? i really need a
working board.
thank you again,
thanks,
________________
was forwarded to tech from cs, and cc'd to me: (8/31/5)
Please refer to the following e-mail. He has a LP UT NF3 250GB board.
Could you please help him?
Thank you.
Best regards,
_______________
from tech: (8/31/5)
Dear Customer,
What kind of voltages you mentioned about, VDIMM, Vcore?
How is your system working, hang up anywhere or can't play over
clocking?
Please try updating the BIOS to see how it works.
Thanks
______________
to tech: (8/31/5)
after i installed the hardware and booted it up. i loaded the
optimized defaults, did a soft reboot, then i was able to change the
voltages and save and exit. during the soft boot i have gone back
into the bios and saved the settings multiple times. however, after i
do a cold boot, the voltages will not stay.
i have an oem 2800+ and a mobile 3400+ (i am aware DFI does not
officially support mobile processors), it does this with both
processors. after the cold boot, depending on the pocessor, the vcore
is .93/1.5.. chipset is 1.6... agp 1.5 ....vdimm 2.5 (where 2.6 is
default).
the cycle will repeat itself only after i let the board set for a very
long period of time with the battery out and the bios jump set to
clear.
_______________
from tech: (8/31/5)
I wonder if you had put the description of the problem when you RMA this
board. You didn't answer if the system board working OK or not or just
couldn't play over clocking. If you don't mind, we can pay shipping to
collect this board to check it out again.
Thanks
_______________
to tech: (8/31/5)
i am unable to boot into an O/S, this not for overclocking. sorry i
left that out. yes, i would like to have another bench check on this
board.
thank you for your patience,
_______________
from tech: (8/31/5)
Please use our FedEx account # xxxxxxxxxxx and the same RMA # ship the
back to us.
Thanks
PS. Please don't ship overnight, it's too expensive.
_______________
to tech: (8/31/5)
thank you very much for the support, im positive you guys can get it
working right or atleast find a replacement. if you have any other
questions reguarding it, i will try my best to answer them. id love
to be updated on it once you recieve it and are able to work on it. i
understand what its like to work on electronics and having a line of
parts ahead of you to bench. it was shipped two day, so you will have
it by friday. the tracking # is xxxxxxxxxxxxx , www.fedex.com . if
you by chance need to track it.
i look forward to hearing from you.
thanks again,
________________
to tech: (9/6/5)
i was wondering if by chance you were able to take a look at the board?
thanks,
________________
no reply...
________________
to cs: (9/8/5)
hello, i was wondering what the status is on RMA xxxxxxx. any
information would be greatly appreciated. have a great afternoon.
________________
from cs: (9/12/5)
Our technician had tested your board again and it’s working fine. Could you please let me know what was wrong with it?
Thank you.
Best regards,
________________
to cs: (9/12/5)
into the bios and saved the settings multiple times. however, after i do a cold boot, the voltages will not stay.
processors. after the cold boot, depending on the pocessor, the vcore remains
at .93/1.5.. chipset is 1.6... agp 1.5 ....vdimm 2.5 (where 2.6 is
default).
clear.
_____________
from cs: 9/12/5)
Thank you for your reply. After talking to our technicians, we’ll just send you a replacement board today and study your symptoms in more detail.
Thank you.
Best regards,
___________
to cs: (9/12/5)
thank you, donna. :)
Not a super experience but to be honest not a bad one either... They didn't let U hang and they even paid for shipment when they misunderstood what had happened. Id give it a 3.5 on a 1 to 5 scale where 5 is best and 1 is worst.
