Custom Cooler Master Elite 340
Dremeled out puny 80mm hole and made it a 120mm. Heres a better look at the side.
Also dremeled out the back fan to get rid of the stupid honeycomb stuff. I love that plastic edging, really cleans up the look.
Heres a shot of the whole back.
WHAT! NO WAY! Yes, yes way. Thats a GeminII in a elite 340. How did i do it you ask? Well, it took a little bit of cutting and a little rubber edging to make it purty.
Well, it took a little bit of cutting and a little rubber edging to make it purty. Since had to cut up the 3.5 bays as you can see, i had to install the 500gb hard drive to the frund of the case.
Ive got 4 kaze-jyuni 110cfm fans in this case all set to silent and im lovin it!
What should I do next/fix?
EDIT:
I went ahead and moved the hdd to the bottom and i have to say, much quiter now. Heres updated pics.
EDIT:
