my crap motherboard
—§urfÅceЗ
I have a MoBo from 2001, its the MSI MS-6579.
I bought my new one, the ASUS A8N-SLI Deluxe
I am now deciding on GPUs, but some say the next generation will dawn soon and I am thinking twice about buying 2 6800GTs.
So I am instead going to buy a top-of-the-line AGP. X850XT. One problem is:
I don't know if my AGP slot is v2 or v3, and i need v3 apparently.
Can anyone tell me which the MS-6579 is?
Uh... Dude? The 7800GTs and GTXs have been out for a few months now. Where've you been? Why would you want to buy an AGP card for an old motherboard?
To actually answer your question, though... That X850XT should work just fine in that motherboard. From what I can see on Google, that's an Intel i845 chipset.
I'm not going 7800 because the rig I'm working on is going to be blue & black & gold on the inside, and nothing else. Therefore, I can't do 7800.
But yeah, thanks for the info on my 6579.
[blink][blink] Wot?
I'm all for case modding... But I'm pretty sure somebody makes a black or blue 7800. Although it seems somewhat silly since your initial worry about the 6800GTs in SLI was that the next generation was coming out, but then you're thinking about an AGP card that gets owned by 6800GTs in SLI.
I guess color me confused... Is confused Blue, black, or gold?
you won't get a video card that is a better value just because you want colors to match?
sounds pretty retarded to me
pretty sure hte BFG cards are blue too...
this has to be the most rediculous reason for buying a card in the world.
Asus 7800gt is blue also. :) Just an FYI for pretty colors. I just bought the EVGA from the egg for 300 plus COD2 free, but it's green. lol
JasonG
[blink][blink] Wot? I'm all for case modding... But I'm pretty sure somebody makes a black or blue 7800. Although it seems somewhat silly since your initial worry about the 6800GTs in SLI was that the next generation was coming out, but then you're thinking about an AGP card that gets owned by 6800GTs in SLI.
LOL!
Makes no sense to me either, buying components based on color, not specs? Just mod the color!
So, like, just the colors, or particular shades? I mean, blue is not blue is not blue. If we assume hexadecimal notation for your color definitions, what is the hexadecimal range the color can vary across and still be acceptable for the rig. Oh, and gold implies a glossiness, metallic sheen, do you use Photoshop or something to determine the appropriateness of the level of light reflection?
:confused:
