my cpu temp... WIT WATERCOOLING
hey guys, i dont kno but i think i put the watercooling in wrong. my temp is 40 C!!!!!!! y is it so hot i dont get it. i got the h220 apex ultra cooling kit. help me!!!!!!!
General Information :
Performance Rating : PR-3800 (estimated)
Real Frequency : 2338.4 MHz
Multiplier : 10x
Startup/Max Multiplier : 10x / 10x
Front Side Bus Information :
FSB Frequency : 233.8 MHz
Initial Frequencies :
Frequency : 2000 MHz
FSB Frequency : 200 MHz
Multiplier : 10x
this is what it says on PC Wizard 2006
what CPU and motherboard do you have...
mine idles at 44C-46C ....thats because IC7s report temps 10C higher...I wish there is a fix for it...it really bothers me to see it that high even though its not :)
heheh nvm, its 29 celcius ahahah joking.. but how can i overclock it? what do i chang ein the bios?
master hows that kit working for ya? does the apogee work as well as they say it does?
If you don't know what to change in the BIOS, please don't try overclocking yet. Read up on it. I'm pretty sure there's some good FAQs and howtos out there on the subject. Google is your friend.
Go to the AMD subforum and look in the second post of the AMD OC Database thread. It basically gives you a step by step walkthrough of how to overclock your processor.
