my cpu specs - need advice
Fokissed
This is my current cpu specs.
http://fokissed.tripsis.net/mycpuspecs
What are the top 3 things I should upgrade for gaming performance? Im really wanting to play EQ2 at medium settings (atleast) without any lag problems. Please provide links to the upgraded hardware, thanks.
I don't see what vid card you have.. you have a pretty old mobo.. I'd go for a new vid card (although this depends on what kind of vid card you have now..), newer mobo, and 1 gig of ram.. you didn't mention your budget.. and FYI - CPU stands for central processing unit, and you shouldn't refer to the whole computer as a CPU, ok? ;)
in the beta I run eq2 at medium settings with my A7N8X deluxe, 2800XP, 98 pro and 1gb of ram. Theres noticable framerate slow down around city areas when numerous players are about (and sometimes when no ones about) , running around the outer zones usually has a decent framerate though.
Hard to say for sure the absolute minimum specs that will run eq2 at a playable framerate, but I think a 96pro might be pushing it for medium graphical settings ~_^
