my cpu can easily get damage?
Status
Not open for further replies.
kopekci
I'm really afraid of having my system damaged. But stability just requires these settings.
CPU Idle: 45-50
CPU Cores Load: over 85:eek:
CPU Load: 80-85
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto
Intel (R) SpeedStep (TM) Tech - Disabled
Intel (R) Turbo Mode Tech - Disabled
BCLK Frequency - 211
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1688MHz
CPU Clock Ratio: 19.0 (19x211)
DRAM CAS# Latency - 7 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 7 DRAM Clock
DRAM RAS# ACT Time - 20 DRAM Clock
(2nd formation: 2T)
CPU Voltage 1.35000v
CPU PLL Voltage - 1.90
QPI/DRAM Core Voltage - 1.40v
IOH Voltage - 1.24v
IOH PCIE Voltage - Auto
ICH Voltage - 1.20v
ICH PCI Voltage - Auto
DRAM Bus Voltage - 1.66v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled
CPU Differential Amplitude - 800mV
CPU Clock Skew - 300ps
CPU Spread Spectrum - Disabled
IOH Clock Skew - Auto
PCIE Spread Spectrum - Disabled
I don't see anything in there that would cause your CPU to become damaged.
If it is stable that should be fine.
i7 can handle up to 100c temps.
As long as you're not at that level 24/7, your CPU will be fine. To be honest, though, the vcore seems a bit high - is it possible to lower it a bit?
Status
